Comand - data connection.
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by jimmcv, Dec 7, 2012.
  1. jimmcv
    jimmcv New Member
    3
    Dec 7, 2012
    London
    Your Mercedes:
    C220 CDI
    Right - I got my lovely new C220 exec this morning and it's great. It has comand and after checking the MB pages and this forum I also ordered a new Blackberry bold 9900 as it had ticks in pretty much every box on the compatibility chart. Several, very cold hours with the 300 page comand module I have it synced to the car and making calls now worries - BUT - can I get the car to go on the WWW? No. What am I doing wrong? I sync, go to the airtime provider and get zip, nada, niente, less than that.
    Any clues or suggestions are very welcome.
    Jim
  2. npuk
    npuk Guest
  3. OP
    jimmcv
    jimmcv New Member
    3
    Dec 7, 2012
    London
    Your Mercedes:
    C220 CDI
    Already been through that when I chose the phone - but thanks. I think it's to do with the access point it's trying to use. Has anyone got the settings for Vodafone access?
  4. npuk
    npuk Guest
    Try a forum search and google search, pretty sure that it normally happens due to some network setting, you need to ring your provider to change something.
  5. Oarsman
    Oarsman Senior Member
    819
    14
    Mar 16, 2010
    Norfolk
    Your Mercedes:
    W221 S350L CDI Bluetec, Range Rover Vogue SE 4.4 TDI, 1963 Triumph TR4
    Are you able to browse the web with the phone?
    I'm not sure you can connect Comand to the web via the phone.
    I have a new S class and I have not found a way to do this as yet.
  6. OP
    jimmcv
    jimmcv New Member
    3
    Dec 7, 2012
    London
    Your Mercedes:
    C220 CDI
    Woo hoo - fixed it - thanks Vodafone - Mercedes pre program the wrong WAP access point. For some reason they use the one in Germany. Changed to the UK and suddenly I can see the weather, read the news and scan facebook while driving....
    Graham - try changing the access point to wap.vodafone.co.uk
  7. AdamG
    AdamG Senior Member
    531
    3
    May 24, 2009
    Bromley, Kent
    Your Mercedes:
    S320CDI (2003)
    Sorry to go off topic but how is the bluetec w221 compared to the w220?
    Adam
  8. Oarsman
    819
    14
    Mar 16, 2010
    Norfolk
    Your Mercedes:
    Generally it's a great car. More interior space, smoother, quieter and faster with some superb toys.
    If I was to make any complaint, it would be that the build seems more plasticky. Nothing seems as solid, but I said the same on moving from the 140 to the 220.
    I still think the 220 shape is the best. Smooth lines and curves.
    But would I swap back......NAH!!!
  9. AdamG
    AdamG Senior Member
    531
    3
    May 24, 2009
    Bromley, Kent
    Your Mercedes:
    S320CDI (2003)
    Thanks.
    I do like the way the w220 hides its size.
    I hope to upgrade to the bluetec w221 someday. I still haven't quite got used to the styling though. The facelift does look a lot better.
    Most people say the 221 is a massive step forward from the 220 but the way my car glides over bad roads never ceases to amaze me.
    Cheers
    Adam
Share This Page
