Alex Green
- Jul 5, 2017
- Cl500/2000/V8 5.0L
Hi all,
I've just checked through the codes on my Comand 2.5 on my W215 CL500 (MY2000) and these pop up.
I've dug around a bit and I'm thinking:
Is 0012 something to do with a sensor on the throttle body or something to do with the accelerator pedal assembly giving up??
Should I change the MAF to a new Bosch unit?
Any insights from you knowledgeable chaps would be greatly appreciated.
Ta
- 0010 is a MAF issue
- B1777 is the ETR (emergency tension retractor) of the driver seat belt has been triggered 3 times and now it needs to be replaced. - Not a problem as I have new seats to go in.
- 0012 is Throttle Potentiometer Actuator??
Ta
