Comand retrofit: If I quote a part no can somone tell if it will PnP?
pcman_jh
Haddington
2013 E220 Cabriolet
On the brink of buying a NTG2.5 Comand for my 2004 E220 CDI which currently has an Audio 20 CD. It looks like I can PnP with the items listed below (Plug and Play with the help of an adaptor cable), but want to be sure the ones I'm looking at will be compatible as I beleive this field is a minefield of compatibiltiy issues.
Anyway Will a A211 870 60 94 PnP into my car,
or
A211 870 50 94
Thanks in anticipation
A 2004 car is Most based, and the Comand 2.5 is not and D2b based
P
pcman_jh
Haddington
2013 E220 Cabriolet
Comand retofit
What if any is the physical wAy of distinguishing a most from a dtb system? At the back of my Audio 20 I have one large connector and 1 phono style connector that either uses fibre optics or is a thin co-ax style cable.
Only from the serial numbers on the units,, they all look the same on the outside
P
pcman_jh
Haddington
2013 E220 Cabriolet
My existing audio 20 has this part no on it - a211 820 98 89 and MF2311
It is very hard checking this way but I will do what I can
Alfie
Surrey/Cotswolds
www.comand.co.uk
or
A211 870 50 94
All W211 cars are MOST based. D2B was used on the earlier cars in other ranges such as the W203, W208, W210 W209. However, the W203 c class was changed to MOST from april 2004 build onwards so in reality that means cars from about late May 2004 onwards. The W209 CLK was made 'MOST' from October 2004 build onwards hence these are all 54 plate onwards.
Fitting an NTG2.5 comand unit into a W211 which has Auduio20 is definately not plug and play. You WILL need a loom adapter at the very least. Also if you have a CD changer, phone pre-wire etc these will no longer work when you have installed NTG 2.5.
All these things can be done but do not underestimate the work involved. Particularly on a W211.
drdre78
london
mercedes c200 200
hi.i think it will be ok.only thing you need to get wiring diagram for your car and the command system so you can move the wiring.such as wire for nav so it knows you moving and need to fit gps ariel.plus need to connect it to star machine to change setting
Alfie
Surrey/Cotswolds
www.comand.co.uk
I am afraid you are very mistaken.
I fit these on a weekly basis and can assure you that there is more to it.
For starters the FM/AM amplification is different. the connections for the antenna are also different. There is more.....
