I had disconnected the battery, screen back on at first, then go's off again and noise persistsUnlikely to be just a fuse… I’d disconnect the power completely for a minute or two and see what it does on a reboot.
Only issue you’ll have is having to reset your windows and clock if you go down the disconnect the battery route
If the head unit is faulty, would this cause the issue? A few buttons seem stuck/jammed in?I had disconnected the battery, screen back on at first, then go's off again and noise persists
Yes I would say so. The unit is confused at what it is being told to do.If the head unit is faulty, would this cause the issue? A few buttons seem stuck/jammed in?
