Comand screen no phone buttons or menu
Eccles,UK
S63L AMG 2007 V8, S500L/1999/V8,SLK 200 Kompressor 2001,Porsche 911 1967 2 litre
I have just bought a W221 2007 S63L AMG, what fun it is when it howls!!!!!
It has all the physical buttons for the phone but there are no menu buttons or options on the comand screen.
Can any one help?
2007 will most likely require some form of cradle or bluetooth adaptor (my 56 plate W211 did) - what have you got in your centre armrest?
P
Eccles,UK
Nothing in the box
Botus
S500/2010/500
….. if the cover lifts and it has some buttons for a phone system, wiring should be in the car.... under the centre console lid you ought to have a UHI socket
you might find a menu for Bluetooth but its NOT for connecting a mobile, so ignore it,
if it has no socket then the lid and the buttons may have been taken from a different car
check if it had a system using a chassis number decode tool
386 MOBILE PRE.-INSTALLATION (MTUS)
388 PHONE MOBILE, MTUS-SYSTEM
if you have the socket, but nothing plugged in then, u need some system for a clip in phone or one of the BT gadgets you can find out there (search other posts)
if its all there, is there sound & radio frequencies on the display... if not the tuner / amp in the boot is dead (very common)
P
Eccles,UK
Thanks it seems as if it was supplied without the wiring
Botus
S500/2010/500
the one UK base model I saw had a completely locked closed keypad it could NOT be opened and there shouldn't be any phone menus
either someone added bits trying to get the feature or there's a bit in the centre console you're missing
check what it came with using chassis number check and or post a photo of the open centre console you get a list like this
Code Value
14N TAX CODE FACTORY (STEUERCODE WERK) SINDELFINGEN/GRAZ
23N STEUERCODE WERK SINDELFINGEN/GRAZ
500A EXCLUSIVE LEATHER TRIM
501A EXCLUSIVE LEATHER - BLACK/ANTHRACITE
205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH
221B SIGN COOLANT/REFUELING - ENGLISH
250B MOBILO LIFE/EUROPE SERVICE PACKAGE
283B AIRBAG LABLE - ENGLISH
537L GREAT BRITAIN AND NORTHERN IRELAND
5XXL EUROPE
775U BRIGHT SILVER METALLIC CLEAR COAT PAINT
218 REAR-VIEW CAMERA
223 REAR BACK REST ADJUSTMENT AND HEAD RESTRAINTS, ELE
229 PARK ASSIST
231 GARAGE DOOR OPENER
233 AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
260 TYPE DESTINATION ON TRUNK LID - ELIMINATION
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
276 MEMORY REAR SEAT
289 LEATHER STEERING WHEEL WITH TRIM INSERT
297 ELECTRIC ROLLER SUN BLINDS IN REAR DOOR LH AND RH
310 DUAL CUP HOLDER
401 FRONT SEAT CLIMATE CONTROL
402 REAR SEAT CLIMATE CONTROL
406 MULTI-CONTOUR REAR SEAT
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
427 AUTOMATIC TRANSMISSION 7-SPEED
432 MULTI-CONTOUR, DYNAMICS SEAT FRONT LEFT AND RIGHT
437 COMFORT HEADREST REAR
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
518 UNIVERSAL COMMUNICATIONS INTERFACE (UCI) / IPOD INTEGRATION KIT
527 COMAND DVD APS WITH NAVIGATION
537 DIGITAL RADIO STANDARD DAB (DIGI. AUDIO BROADC.)
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
581 AUTOMATIC CLIMATE CONTROL
582 AIR CONDITIONER IN THE REAR
595 HEAT INSULATING+IR REFLECTG.SAFETY GLASS SIDE+REAR
600 HEADLAMPS - CLEANING EQUIPMENT
610 NIGHT VIEW ASSIST
616 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT LEFT-DRIVE
619 CORNERING ILLUMINATION
666 PRODUCT PROT.F.TRANSPORT VEH. W/O TIE-DOWN HOOKS
669 SPARE WHEEL / FOLDING WHEEL
682 FIRE EXTINGUISHER
731 TRIM PIECES - WOOD BURRED WALNUT VENEER
807 YEAR OF MODIFICATION
814 DVD CHANGER
856 PHONE HANDSET IN REAR ARMREST
863 TV-TUNER DIGITAL TO ANALOG
875 HEATED SCREEN WASH SYSTEM
882 INTERIOR SAFEGUARD
883 POWER CLOSING SYSTEM
885 HIGHTEN THEFT PROTECTION
910 DYNAMO WITH HIGHER CAPACITY (FFO)
983 COC PAPER EURO 4 TECHNOLOGY W/O REG. CERT. PART II
989 IDENTIFICATION LABEL UNDER WINDSHIELD
A21 SHIFT BY WIRE
A22 NEW CONVERTER GENERATION
A24 JOINT FLANGE, 4-ARM 120
A45 O-SHIFT PLATE WITH VGS2
K10 SOFTWARE CONTROL FOR STATIC CURVE ILLUMINATION
K11 ADAPTIVE STOP LIGHT FLASHING
M273 V8-GASOLINE ENGINE M273
M55 CAPACITY 5,5 LITRE
R01 SUMMER TIRES
R24 17" LIGHT-ALLOY WHEEL 5-SPOKE DESIGN ALL-ROUND
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
V23 SPEED- + LOADINDEX 99W
System information
Code
Value
Data language en
DB storage version 1.0
Data display version 2.0
Manufacturer's data version DW 07/2014 Delta 1 from 2014-07-10
Botus
S500/2010/500
I just read the first post ... S63L AMG
I don't believe it would not have had a phone system... as in you aren't looking for the right bit and or hard enough, its small if nothing plugged in maybe 25 x 30mm and might have a small cover
Being the “L” it could have another phone in the back...
Botus
S500/2010/500
I wonder if you could have only rear system (doubt it) on mine that option is why it has a Bluetooth connection.... you can try to connect a phone to it but it doesn't bring the speakers in to play but it does the Mic !!! so you can see it ring and can answer, but hear nothing whilst they hear you
Alfie
Surrey/Cotswolds
www.comand.co.uk
I always find it staggering that someone ordered a car such as this and didn't tick the 'Phone pre wire option' (388/386) at £300. Its around £2,000 to retrofit the option as there are many many parts required.
P
Eccles,UK
I downloaded the VIN list and no phone option listed, but it does have the TV, quite bizarre really.
As to retrofit Comand Online quoted me £2500, I think the bluetooth headset will have to suffice.
But the engine is so god to listen to I can always turn off my phone.
Thanks for all your replies.
ab9758
ML500 2007 308bhp
You're going to have to accept some very dated technology I'm afraid. My former ML63 (2007) caused the same issue and the "half-way house" solution is a Viseeo MB-4. It clips into the cradle in the upper arm rest.
https://www.carcommunications.co.uk...luetooth-handsfree-new-mb-4-bluetooth-adaptor
Strongly recommend eBay as full price retail is madness.
However, this is not going to let you stream/play music from your phone onto the Comand system. Nor (in spite of its claims) will it reliably store your phone book contacts if quite large (mine is over 1,000 and the unit just "hangs" after 20 minutes.
It is simply a way for your bluetooth enabled smartphone to use the Viseeo as a bluetooth connection to the Comand phone.
It won't (I think) for instance stream map directions from your phone to your speakers.
I'm fairly certain I couldn't get it to make hands-free call dialling - but not sure
Alfie
Surrey/Cotswolds
www.comand.co.uk
He doesnt have the UHI phone connection point so the viseeo wont work for him.
Also, viseeo MB-4 and MB3 products are not available new anymore. they went out of production about two years ago. some may have old stock laying around.
the MB-4 isnt as good as the Mercedes HFP either. For earlier D2B cars (pre 2005) the Viseeo MB-2 (if you can find one) is the better cradle.
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
There are some strange first owners of S Classes... The 2006 LWB I had, came with rear entertainment, but no TV tuner. Managed to get one off ebay in Germany that came with all the components inc. the rear screen aerial but it took a good day to fit... seats out and everything.....It also had the buttons on the mirror to open garage doors... but who on earth has a garage long enough to fit a LWB S Class in???
Botus
S500/2010/500
I'd expect every single owner of a 500L,
with a couple of essential toys (not TV) they were are well over 110k new in 2006 add the creaky roof and ABC they were over 127k GBP
