Command 2.0 wiring issue
Maggra
I have a 2000 CLK 230 Komp with a single DIN CD player fitter - standard ISO connection x 2 and a 3rd which is the CANbus control. Have now bought a MERC original Command 2.0 Unit (A208 820 40 89), its got the standard ISO connections for Power and speakers but has a different connection format for the CANbus ie 18 pin (2 rows of 9) also a much smaller 6pin connector? I'll be fitting over the weekend so I don't expect any problems with the sound system but using the steering wheel controls will be side-lined until I can get hold of a cable adaptor harness to match connections of the CANbus so any suggestions would be greatfully accepted. Note: I'll sort the SATNAV/GPS side out later, have identified GPS aerial but would like a combined GPS/FM unit so again any suggestions, thanks in-advance
M
Maggra
  • #2
wiring of mentioned connections
found the following in answer to my question which may help others to resolve their's.....,
http://www.mercupgrades.com/COMAND FAQ-faq-1.html
Comand C1 connector.,
1 RGB-Video Red 5 CD Changer Ground
2 RGB-Video Green 6 CD Changer +12
3 RGB-Video Blue 7 RGB V-Sync
4 RGB-Video Gnd 8 RGB Shield
Comand C2 connector.,
1 not connected 10 D2B Wakeup
2 TV-Audio Right 11 TV-Audio Left
3 TV-Audio Green 12 TV-Audio shield
4 Aux-Audio Right 13 Aux-Audio Left
5 Aux-Audio Ground 14 Aux-Audio Shield
6 Speed Signal 15 Reversing signal
7 CAN-B Shield 16 CAN-TV Shield
8 CAN-B LO 17 CAN-TV LO
9 CAN-B HI 18 CAN-TV HI
Pleased that you found the answer, not always easy owing to the amount of searching
pancholi
1996 SL 500 , 2003 CL55K, 2004 E320CDI
sorry can we put this thread in the electrical section, is it saves a lot of head scratching!!
M
Maggra
now have silly issue's
Now my comand dx goes off when the ignition is turned off but not when I return to the car ? I have to push a button to bring it out of hibernation / screen save! is this normal?
Yes that is correct, but there are several versions of the DX the very first mod came in 07-02 when the set up was changed to over come this. I think that there is a time out point for it to shut down altogether, if the "go to sleep" has kicked in,then you have to start it up again, for a short break say filling up etc this should not happen
