MercStraight6
- Apr 7, 2009
- 1995 W124 E280 estate
When I bought my W124, it would select between hot and cold air for the side vents perfectly, but after a few months it would only blow hot air.
I thought that the Duo-valve may be at fault, because I had the same problem on my last W124; the brass plunger had snapped off its arm, and I fixed it by rebuilding the the duo-valve.
So the other day I took the Duo-valve apart, but everything appeared to be in good order, so I put it back together and tried it again, but I'm still getting hot air.
Is there anything else in the system that could be faulty?
