Converting TV to digital
AndrewIles
Alton, Hants.
SLK 55 AMG
Television,
I see that you have upgraded your car's tv to digital using a small Bush scart freeview unit.
I would be really interested in knowing how you did this. Could you run through the stages for me please?
I have got a C32 AMG Estate. Do you have any idea where the analogue tuner would be?
Thanks for your help. It is appreciated.
I have printed off the retro fit for the TV tuner as you can see where every thing is, take a read to find where the things are.
I need your Email Address please
AndrewIles
AndrewIles
Alton, Hants.
SLK 55 AMG
Thanks Television.
Thanks Television.
.co.uk
Go back to your post and in "edit" remove you address
Take a read to see where all of the parts are and we can take the next strp
AndrewIles
AndrewIles
Alton, Hants.
SLK 55 AMG
Thanks Television, just received the email.
I've got an estate version, will the components be in the same place as the saloon version?
AndrewIles
AndrewIles
Alton, Hants.
SLK 55 AMG
Hi Malcolm,
At long last I have found the TV tuner in my car. It is beneath a Bose bass speaker so it is not that easy to get to.
Do you have a DIY write up I could follow?
I cannot see where the Aux inputs are. Any ideas?
Also I have a 12v socket in the boot area as my car is an estate. Presumably I can tap into this for the power.
Hi Malcolm,
There should be 2 RCA sockets on the rear of the tuner, and you need to be able to switch to the AV1 and 2 from the TV menu, best to make sure that you have those
AndrewIles
AndrewIles
Alton, Hants.
SLK 55 AMG
I definitely have AV1 and AV2 on the screen.
The sockets are probably just out of sight.
Would it be ok to use the power supply to the 12v socket in the boot in your opinion?
If it switches off with the car locked then fine and you can use it, if not the cigar lighter in the cab, front or rear
AndrewIles
AndrewIles
Alton, Hants.
SLK 55 AMG
Malcolm,
I have managed to remove the Tv tuner to have a good look at it and I can't see any RCA sockets.
The only connections are on the top of the tuner as per the attached picture.
The only connections that are in use are the top left one for power and the largest of the middle bank of connections which sends the signal to the Comand unit.
Could it be that I need a specific multi-pin plug from MB to fit additional AV equipment?
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
I think your tuner is the same one as I have in the garage. It is from a pre facelift S Class (and maybe others) and needs a seperate lead to access the AV.
I am pretty sure this lead I have is wired to provide AV Out as it was used to put the display onto additional screens in a 2002 S Class. I don't see why it can't have the pins moved to the correct positions to provide an AV input. This is the wiring pinouts for your TV Tuner
baz
turbopete
Spennymoor
i cant help with your question but would i be right in thinking you liked mid-late 60's corsairs? must be among the few fords ive not owned that i may have seen! i wasnt born till 75 either! lol!
barry jones
Warrington
I do indeed like my Corsairs....I currently have 3 of them. One a daily driver, one being rebuilt and one as a spares cars.
I have my own Corsair forum at www.fordcorsair.co.uk pop in and have a look round!!
Baz
husaberg
Bulgaria
2002 C32AMG
I can't send Television a message, so i will post a reply.
Can you send me the DIY for the tuner retrofit, so i can isntall it in my C32 estate
My email: supermoto570@abv.bg
Thank you very much
Does the car have a TV tuner in the car.
www.ckinsurance.co.uk
