coolant change on 1984 230E (W123).
taylor20
1984 230E
Hi all
Being new to MB ownership some advice is sort please. My coolant has been tested to -15 and the mechanic recommended changing it (certainly before winter).
Any particular anti-freeze I need to use? (MB's own or will local halford's one do?)
Is it an easy job - anything to watch out for? airlocks in system?
Many thanks
I would do it by removing the bottom hose, its easier from the rad.
It is said that MB antifreeze is the best and I would use that and I would flush it out too
turbopete
Spennymoor
It is said that BM antifreeze is the best and I would use that and I would flush it out too
i hope you mean MB antifreeze there Malcolm! dont want people having to go to the 'dark side' for antifreeze do we??!! :shock::shock::lol::lol::lol:
T
taylor20
1984 230E
Thanks Malcolm- by 'flush' you mean run a hose pipe through for 5mins or so??
turbopete
Spennymoor
oh come on Malcolm. no offence meant but i think you're allowed a couple of off days at your tie of life, especially with as much knowledge as you have swimming around in those grey cells of yours!!!
wireman
lancashire
If you are unsure of your cooling systems history put a dose of chemical flushing agent through it, follow the makers procedure.
If there is sludge in your engine, radiator or heater it will not wash out with any hose pipe not even a fire pump.
Change your coolant at 2 year intervals and use a 50% mixture.
It is the corrosion inhibitor component which is essential in modern engines, miss out this service and trouble may (eventualy will) come to visit with a very large bill.
T
taylor20
1984 230E
Thanks - how do I get rid of any air in the system once i have refilled with antifreeze?
You do not have to, but a good way when filling up is to fill up as far as you can then squeeze the bottom hose, and any bubbles will come up to the top
T
taylor20
1984 230E
many thanks Malcolm - thats next saturdays job - Will go with your advice on MB antifreeze £18 for 3l (only a few quid more than local car parts shop...)
stever
Any anti freeze with MB approval printed on the label will be ok - Halfords sell one. Once you've refilled, run the engine for a short while and then re-check the level - it will probably need topping up again.
www.W140.co.uk&www.r129.co
