coolant leak
simon winn
oxford
Morning,
My E320CDI has been losing coolant (slowly say 1/2 lt per fortnight). I have so far failed to find the source.... Have had a new thermostat fitted and it appears dry in that area. All hoses seem dry - any ideas on where else I could check? Simon.
Hello Simon,,it take it that the car has no vibrations or humming when pulling lightly in top gear.
I would also have someone check the gearbox fluid level, just in case the rad is leaking into the box
Check the bottom hose, if the car has ever had the normal fuel leak, then the bottom hose goe,s soft and leaks slowy!!
jonclancy
Dredge-a-thread!
Sorry to resurrect an ancient thread, but I had similar symptoms recently.
It turned out to be the O-ring on the EGR heat exchanger. A new ring cured the problem.
Hope this helps someone!
Jon
www.ckinsurance.co.uk
