Coolant Level Sensor
coventryslk
Coventry
W204 CDI Sport
I have changed the coolant level sensor a week ago and the light still comes on intermittantly.
Any ideas of loose wires/connections to check? shorting?
I do not want to take it into a garage to sort out.
Matt
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Change the washer bottle switch, due to the way they are wired, when it becomes faulty it puts the coolant level light on.
There not very expensive when i replaced mine it was less than £15.
was not the car a slk do you have the first 6 vin numbers
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Agree the sensor in the water tank, you can remove it and clean the contact but for the cost of a new sensor and a few cuts its worth replacing.
Does your interior light work ok?
jib
coventryslk
coventryslk
Coventry
W204 CDI Sport
Thank you Malcolm. Will give you the VIN - Its a 2000 R170 200k
The washer light only comes on when the washer bottle is empty (solved the egg smell - washer fluid didnt mix with stuff already in the bottle and gave off a chemical reaction )
"Change the washer bottle switch, due to the way they are wired, when it becomes faulty it puts the coolant level light on.
There not very expensive when i replaced mine it was less than £15."
So you suggest it is the washer bottle switch?????
It has also been suggessted that it could be the control unit on the electric fan??
Im confused?? Matthew
nickid
coleraine
YELLOW LIMITED EDITION 2002 MERCEDES C 230 KOMPRESSOR SPORT WITH 2 TONE LEATHER
mine is in the same boat. both faults washer and coolant and both are full. just bought the car so I am worrying a bit
barose
Peterborough
E350 2011 Obsidian Black, CLS350 2013 Silver
Washer fluid low error message
My CL600 just started giving me this message (full reservoir of course), now it is on all the time. It hijacks my message centre can this be removed with the reset button whilst driving.
I drained the tank and refilled it, pulled off the sensor wire and refitted it, to no effect. How do you replace the sensor as the opening is too small for a hand. Any suggestions and help would be appreciated
The header tank and washer tank sensors are resistive and wired in series, it could be either one
nickid
coleraine
ive just changed my coolant sensor and it fixed both faults
