Coolant smell when...
230ceBruno
I detect a faint coolant smell when the cars temp is a bit high and the fan kicks but this happens only when the heater is on as well. Hm what could this be...
230ceBruno
What is a leaker matrix and how do I find it
Ultymate
N. Wales
C230K Estate 1998
Your heater matrix is a small radiator buried deep within the dashboard of your car it's purpose is to transfer heat from your engine into the air entering your car via the heating and ventilation system in order to keep you and your passengers comfortable
P.S. Heres alink to a schematic it's item No. 11 called a heat exchanger http://www.detali.ru/cat/oem_mb2.as...215717.401&CT=F&cat=223&SID=83&SGR=030&SGN=01 hope this helps
There are some super liquid sealer used by the trade today, so much better the the older type that could block the Matrix, these will also cure head gaskit problems.
Malcolm
Well I thought,no one will ask,to save finding the article, but 24 mins later!!!
Kalimex K-Seal is the one, should be available from people like Parts Co.
Malcolm
Dont forget that our heater air intakes are at windscreen level, if you have the correct wndscreen agent added ,it does smell like Anti freeze.
Malcolm
230ceBruno
Well I did change my radiator recently and before that I used the K-.... rad seal in my coolant. If it were the matrix should it not be fixed by that application?
What other symptoms are there of a faulty matrix
Hibbo
East Scotchland
You will lose coolant.
If it is this I'd get it sorted ASAP as you don't want water leaking out all over you dash = rotten carpets and knacked electrics.
eric242340
Banned
China
Coolant
This can occur for many reasons, the heater matrix is only one , is the carpet wet, yes or no, it no then its not the heater matrix.;)
Hang a air freshiner of your choice from the front air intake grill :cool:
Malcolm
eric242340
Banned
China
Malcolm
Maybe Benz girl could give a choice of scents? Benz girl (where are you) are you watching. Maybie a Frence fragrence or Italian - whats your choice.:p :p :p :D
