Cooling Fan comes on when car started
RImzyy
London
c180/01/2
Hi All,
Im new to this so please bear with me. Mercedes W203 2001 C180 Classic
Recently the cooling fan came on when the car was started and comes on every time the car is started and doesn't stop till its switched off.
I have had the car checked by a garage and they changed the fan & the fan sensor however this was not the problem. A Mercedes specialist came out and advised it was the 'refrigeration sensor' which needed to be checked. Another MSpecialist checked the car and told me it needs a AC regas.
Can any advise on this ?
Many thanks
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Oil in the engine harness and ECU at a guess. I could be wrong mind.
jib
EmilysDad
Bury Lancs
ML350
No idea about my Merc ..... but one of the rad fans runs when ever the a/c is on on my other car (Vauxhall) as IIRC it does on EmilysMum's Smart
mersum1es
Finland
ALL fuses checked (BOTH engine bay boxes)?
Fan control unit, faulty AC sensor, ECU lack of voltage...
Why Malcolm?
jib
Oil is not conductive in any way, take a speed plate with all the tracks have gearbox fluid flowing over over them
On a 203 this fan is part of the aircon, I am sure that it uses a relay to hold the fan off, I am trying to find some more details.
Cole@MBS
www.mbssouthampton.co.uk
124 300 CE 24 Coupe, C220CDI,
The 203 cooling fan runs from PWM from the engine ECU, the PWM wires is different from the engine loom..........
R
RImzyy
London
c180/01/2
Hi All,
Took the Merc to Wayne Gates in Harrow and ran a diagnostics. Turns out it was the temp sensor. So it has been changed now. I was quite annoyed that most garages I took the car to didn't know this.
Anyway thanks for the advise.
R Imzyy
