Yaşadığım ölkədə DPF yoxdur. Burada mənə yalnız proqramı yazmağı və ləğv etməyi təklif edirlər.DPF -ni çıxardığınızı və indi bir probleminiz olduğunu söyləsəniz, tamamilə sıfır simpatiyam var.
Karma orospu deyil.
Karma
DPF avtomobili alanda çıxarıldı. DPF alıb hər şeyi qaydasına salsam, soyutma düzələcəkmi? Bu EQU ilə əlaqəli ola bilərmi?DPF -ni çıxardığınızı və indi bir probleminiz olduğunu söyləsəniz, tamamilə sıfır simpatiyam var.
Karma orospu deyil.
DPF was removed when he bought the car. If I buy DPF and fix everything, will the cooling be fixed? Could this be related to EQU?
What is this “Google“ of which you speak…Good ole Google translate....
Google translate.... Turkish to English: There is no DPF in the country I live in. Here mənə only offers to write and learn the program.What is this “Google“ of which you speak…
He’s not typing in Turkish though…Google translate.... Turkish to English: There is no DPF in the country I live in. Here mənə only offers to write and learn the program.
Hours of fun
Interesting, it looked a little Turkish to me and Google translate didnt seem to mind it being recognised as such, hence quite a good translation. I feel... Hopefully we hear back from the OP...He’s not typing in Turkish though…
Azerbaijani is his language
Probably...I think LK scared him off
Probably...
I'm just a lot ****ed off with people removing DPFs.
W212 E350 CDI year 2010. If I do not update DPF. If I change and program the ECU, do you think the cooling fan will always work? Or should DPF be a must?Full cooling fan operation indicates a comms issue with the ecu. Most likely writing the software failed, or something else related to the programming. Recover the ECU in boot mode, or get another ecu
