Copied CDs Drive MLs Player Nuts
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hello all, just purchased a 99 ML320, still got its standard radio/cd but doesnt want to play any copied CDs only originals. I presume its the way the copies are burned that it cant find the start of each track, you have to keep fiddling with the track selection button and then it plays the tail end of one track and the continues to play the the rest as long as you dont skip a track. Is there a way of burning these CDs that it will recognise?
Mike
M
MercAl
There were a few posts about this a wee while ago, with various opinions re burning discs. I can't remember exactly, but I think the general census of opinion was to use decent quality blank discs, and burn at as slow a speed as possible. Are you using Nero? I think it was recommended as well. I'm sure a quick search will throw up the relevant posts.
I use 'Infiniti' Discs, which seem to be decent quality. They cost anything between 10-15 pounds for a tub of 100, and no problems so far, (touch wood!), although I seem to remember someone saying that some players just would'nt play copies. Don't know if that applies to yours...hopefully not!
Sorry I can't be more help, but I'm no expert.
M
Mikesmerc
Co.Cork IRL
Thanks for that Al, will try burning at a lower speed and get some decent quality discs. God knows what Im using to burn, I sit in front of a computer every day for 16yrs now and I still cant tell you what size/speed/capacity etc they are, just no interest in them, until I try to burn a CD.
Cheers
Mike
M
MercAl
If you want to PM me your address, I'll burn a disc using Nero, make sure it play's in my player, and then send it over to you. If it plays in your's...Bingo! Then you just use the discs and burning programe!
daveenty
The Frozen North :(
2019 AMG S Class Coupe
@Mikesmerc,
PM me with a valid email addy & I'll send you a brilliant proggie which will burn all your requirements.
All work fine in my motor (Audio 50...can't afford COMAND) :(
turnipsock
Port of Menteith
there seems to be a lot of cats and dogs featuring in avitars at the moment...am I missing something?
daveenty
The Frozen North :(
Mine's just a little kitten...doesn't smoke cigars :)
Have several more which I may use at a later date. (Sorry, like cats :D )
