Cost of Parktronic for New Type C Class
Hello and welcome,,,it is not that cheap and I can check later in the day to see if a retro fitting kit is available
*Thumper
Banned
Warwickshire
C220 CDi (09)
Yes you can retrofit ......... not called Parktronic though !!
It's called "quickparc " ........ and it's £226 ............. fitting is probably extra
M
mercedessupreme
Is that £226 to have both done or is it £226 for the back?
Good how to in the DIY section
whitenemesis
CLS55 AMG '05
Parktronic can be retrofitted and for the 203 costs approx £1800.
Quickpark is a rear only dealer fit option again for the 303 is approx £500.
There much cheaper after Market options that work equally well..
Beaucoupnice
Worth knowing quickparc is audio only.
Parktronic is installed in the factory as the wiring needs to connect from the back to the front of the car so the proximity lights can be connected.
Quickparc being only audio has a speaker located at the back.
May as well get an audio parking sensor unit installed with a non-MB merchant it may save you some pennys.
whitenemesis
CLS55 AMG '05
Quickparc is not audio only. Mine (genuine MB) has the segment display mounted on the headlining, visible in the RVM. It has audio as well.
There are a number of places that will retrofit the full Parktronic (Braybrooks is one )
Aftermarket, non MB will definitely be cheaper!
www.W140.co.uk&www.r129.co
