EmilysDad
Michelin's guidelines are that new tyres should go to the rear & Costco hide behind that & won't move. Likewise when I wanted just 2 tyres for my R Class .... they'll only fit 4 because it's 4 wheel drive.
I had a similar argument years ago with a tyre fitter. They would only fit new to the rear (on a front wheel drive car. In the end I said fine, do it. Then took it out their bay, jacked it up with my jack and swapped them front to rear myself in front of them. Never went back......
I can understand that but to lose the back end takes some dangerous driving in my books.The argument with fitting the new tyres to the rear is that most peeps can deal with a slight front end slide but when the rear lets go it does big style and comes round on you which most can’t deal with.
On a front drive car all your braking, acceleration and steering is done with the front wheels. All the rears are there for is to stop the bodywork dragging on the ground.
It doesn’t though and when it goes it goes fast, front end goes with much more notice. Understeer is built in and people are used to the front taking a wider line that they plan when hard on the gas. From the back end following nicely to going backwards through the hedge is a mere nano secondI can understand that but to lose the back end takes some dangerous driving in my books.
go back. they should at least have given you the option of straightening it FIRST. mind you,frankly ,with hindsight ,next time give yr wheels a good look over BEFORE taking car in. i go and watch,whenever this goes on with my cars.
If you have front grip you have control.
All manufacturers recommend it because it's the safe option for 90% or more of drivers hence avoids litigation.All tyre manufacturers recommend it, Michelin really push it
90s RR classic was viscous coupled automatic engagement of centre differential. Everything else was manual engagement.on my G,s i always put new on rear, mind you i never let fronts get bad. and i had option of 4 wheel drive,remember? the days when it was considered that we were bright enough to "decide" if or not to engage 4x4 also, remember G was sincro transfer and hydraulic activated diff locks not like L/R, ALIAS MF. i remember 1 xmas in amboseli it poured down and i spent a day dragging "sheds" ,sorry L/r ,s out of the mud
More usually trying to go too far before engaging it. If you're stuck it's too late....maybe those i was pulling out dont know where levers were ?
