Could my mercedes CLK 240 (G Reg) tow a CARAVAN???
Discussion in 'General Mercedes-Benz Related Discussion' started by Anna Sz, Jul 9, 2019.
  1. Anna Sz
    Anna Sz New Member
    3
    Jul 9, 2019
    east sussex
    Your Mercedes:
    CLK 240 G reg
  2. LostKiwi
    LostKiwi Senior Member
    19,532
    9,213
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Depends how big!
    Anna Sz likes this.
  3. John Laidlaw
    John Laidlaw Senior Member
    21,180
    5,935
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    Welcome, can’t answer your question sorry but there are experts in towing on here - @keefysher for instance and @Craiglxviii
  4. Blobcat
    Blobcat Moderator
    16,122
    4,180
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Hello and welcome,
    You need to find your VIN plate (example below)
    If you don't have a number where the 4000 is below then your car hasn't been type approved for towing
    The 4,000kg is the gross train weight (the combined maximum allowable mass of the vehicle and trailer)
    The 2,135kg is the Gross Vehicle weight (the maximum allowable mass of the vehicle including occupants, fuel and luggage)
    The 1,050kg and 1,1115kg is the maximum axle loads for the front and rear axles
    So taking 2,135 from 4,000 gives a maximum tow-able weight of 1,865kg working on 85% gives 1,585kg for a trailer / caravan.
    You shouldn't really be towing at 100%, 85% is the recommended limit
    Jim2 likes this.
  5. Abb
    Abb Senior Member
    474
    32
    Jan 2, 2009
    Your Mercedes:
    Mercedes
    A G reg CLK??
  6. Blobcat
    Blobcat Moderator
    16,122
    4,180
    Your Mercedes:
    Good point, '97 were the first ones - "P" or "R" reg although I doubt many have survived the tin worm from then
  7. OP
    Anna Sz
    Anna Sz New Member
    3
    Jul 9, 2019
    east sussex
    Your Mercedes:
    CLK 240 G reg
    Thanks for your help!! Ill find my Vin plate...
  8. OP
    Anna Sz
    Anna Sz New Member
    3
    Jul 9, 2019
    east sussex
    Your Mercedes:
    CLK 240 G reg
    ok I found it!
    my Gross vehicle weight is 2030 kg
    my Gross train weight is 3530 kg
    my front axle is 1020 kg
    my rear axle is 1070 kg
    so if I follow you correctly, my max. towable weight is 1500 kg but i should only use 85% of that which is 1275 kg...
    am I correct?
  9. Blobcat
    Blobcat Moderator
    16,122
    4,180
    Your Mercedes:
    Yes - :)
  10. keefysher
    keefysher Senior Member
    3,459
    1,337
    May 4, 2007
    Hampshire
    Your Mercedes:
    W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
    A quick note of thanks to my apprentice Blobcat for his timely and correct interpretation of the data plate :geek::rolleyes::shock::D:D:D
    Anna Sz you might find a tow bar here:
    https://www.pfjones.co.uk/tow-bars/...mercedes-clk-cabriolet-towbars-1997-2002.html
    Please establish if your proposed caravan has a stabiliser hitch, in which case you will require a suitable tow ball, not the std two bolt one, but an extended head to provide sufficient vertical articulation.
    Also the electrics require confirmation of 13 pin or N&S (2 plugs/sockets) to power the fridge and any stability control system you may have on the caravan.
    Long gone are the days of just bunging it on the back :eek::D
    Jim2 and Blobcat like this.
  11. Bogus
    Bogus Active Senior Members
    58
    39
    Aug 15, 2009
    Edinburgh
    Your Mercedes:
    W124 230E 1992. Toyota Hilux Surf 3rd gen
    The 85% thing is a guideline, and probably makes sense for somebody new to towing, but dont let it get in the way too much, if your van comes in at something just over the 85% dont go thinking you cant tow it. Its about much more than weight percentages, how you load the van and car is just as important, and you,ll get lots of good advice on one of the caravan forums.
    Blobcat likes this.
  12. keefysher
    3,459
    1,337
    May 4, 2007
    Hampshire
    Your Mercedes:
    Practical Caravan.
    Not Caravan Talk, Club Together unless you are in the clique :geek::rolleyes::shock: always good for a wind up though :cool::cool:
  13. Bogus
    58
    39
    Aug 15, 2009
    Edinburgh
    Your Mercedes:
    Caravan talk is generally ok with lots of good advice , albeit a bit overmoderated, its the caravan club forum that is cliquey and needs to be avoided at all costs.
  14. EmilysDad
    EmilysDad Senior Member
    7,612
    1,480
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    The 85% 'rule' is an abitary number from the Caravan Club ..... it has no legal standing. ;)
    All the rest of your post though I fully agree with. :):)
    ..... maybe I should have read all the thread before adding my post.
  15. EmilysDad
    7,612
    1,480
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    Also ..... depending on when you passed your test you might be limited to a gross train weight of 3500kg
    bembo449 and Blobcat like this.
  16. Blobcat
    Blobcat Moderator
    16,122
    4,180
    Your Mercedes:
    No legality mentioned, just “recommended” :)
    Having no idea on the OP’s experience, erring on the side of caution is a good place to start...
    EmilysDad and LostKiwi like this.
  17. Craiglxviii
    Craiglxviii Senior Member
    14,422
    3,735
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Motorway Queen; W251 R320L Familybenz, S211 E320 Avg Designo Edition now sadly missed.
    Depends how big the caravan is. Your car’s handbook will have maximum towing weight listed; you will certainly be able to tow a caravan. There are two factors to consider:
    1. The absolute weight of the combined vehicle train (shown on your car’s inspection plate as MGTW), this is the car’s limit.
    2. The ratio of caravan weight to your car’s kerb weight, should not exceed 85% as a good rule of thumb.
  18. bembo449
    bembo449 Senior Member
    3,496
    881
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    w221 320cdi , r170 23k , range rover vogue , insignia vxr , shitron dispatch
    im always amazed when I see certain cars towing caravans , there no wonder the get into bother doing so , too many put a big assed van on a weedy little motor , I saw a kia cee'd towing a massive twin wheeler last week :shock:
Share This Page
