Henkka
- Oct 18, 2021
- W124 coupe 1988, 2.3l
Not sure if this is the correct subforum to post this. My W124 coupe door seal is leaking on both the passenger side and the drivers side. There is a small ”gap” between the seal attached to the rear window and the door when you close it. I’ve tried various silicone products to fix it but it just doesn’t provide a permanent solution. Is it possible to tighten the door or move it back a couple of millimeters so it doesn’t leak? I’m looking to buy new seals but not right now.
