Cracked piston on 2017 c300 coupe
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Honey, May 22, 2020.
  1. Honey
    Honey Member
    14
    11
    May 21, 2020
    California
    Your Mercedes:
    2017 C300 coupe / 2005 C230 kompressor
    Hi, My 2017 Mercedes C300 coupe broke down recently. Started to jerk and lose power and white smoke was coming out the exhaust pipes. So I had it towed to the dealership. This is what they said
    "Mercedes"-Hey Honey, so looks like your probably going to need a new engine!! Still confirming but looks like one of the pistons cracked. You're under warranty so its totally covered. I should know for sure in the next day or 2 but plan on keeping that loan car for awhile, may be a couple weeks
    "Mercedes"-Honey just wanted to give you an update. It turns out they don't have to replace the whole engine. They are replacing the turbocharger and they have to replace one of the the pistons.
    "Honey"-Hi Dan, thank you for contacting me. To be honest I do not feel confident in that repair. What kind of warranty is Mercedes willing to put on the engine once the repair is performed. There could be underlining problems as a result of that day when the car broke down. After some research and speaking with the other service centers "SD Mercedes, MB El Cajon" I would feel more confident and safe to have that engine replaced. (MB El Cajon said they are replacing one of those engine a week ).
    "Mercedes"- I understand but nothing is wrong with the engine. We replaced the engines sometimes as well but in this case there is no damage to the cylinder sidewalls so there is no need to replace the whole engine, only the piston was cracked. That does cause underlying damage to the turbocharger as well which is why we are replacing that too. Unfortunately mercedes makes dealerships prove every warranty repair we do is needed so they will only allow us to replace what is damaged. The warranty is the same 4 year 50,000 warranty that came with the car at time of purchase, no extension or anything when a warranty repair is done :(
    "Mercedes"- Basically one of the pistons cracked, which is why you had so much smoke the oil got through and it was burning oil. So we inspected for any damage in the engine, there was no other damage other than the piston being cracked. We replaced the piston then also the turbo charger and the catalytic converter due to all the smoke and burning oil. Refilled all the fluids and everything then test drove and all is good. The technician has his report on the paperwork as well with much more details on what he did (little over my head lol).
    What should I do? Should I be getting a new engine since that is the remedy at other mercedes service centers?
    Thank you
  2. John Laidlaw
    John Laidlaw Senior Member
    23,381
    7,161
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    Welcome Honey
    usually over there you have more power over MB than we do!
    For me, provided you get the car back with all this work done and its working, you're no worse off than you were before the failure so I'd personally accept. If anything goes wrong throughout the remainder of your warranty you'll get it rectified anyway.
    On that subject is it a 3 year warranty you have? If so, for sure extending it is the right thing to do, that might be a negotiating point - discounted extended warranty?
    Jim2, Wighty and Honey like this.
  3. OP
    Honey
    Honey Member
    14
    11
    May 21, 2020
    California
    Your Mercedes:
    Thank you, I am worried that the car may have a problem down the road as a result of the engine failing and then me be out of my warranty because I only have 1000 miles until it expires
    Jim2 likes this.
  4. bembo449
    bembo449 Senior Member
    4,585
    1,594
    Jan 2, 2012
    gainsborough , lincolnshire
    Your Mercedes:
    w221 320cdi , r170 230k , land rover discovery 3 , insignia vxr , shitron dispatch
    Think i agree with john on this but id request the warranty on the engine start again and not just run to the end of the original warranty
    Jim2, Honey and John Laidlaw like this.
  5. ajlsl600
    ajlsl600 Senior Member
    3,909
    1,613
    Nov 18, 2013
    france
    Your Mercedes:
    Think as said. But get the warranty extended by them. Or failing all else you. There is a good chance that's the end of the matter. I would want a Detailed account of all work done and why, cause. Then collect info on as many other cases as poss then wait. If work carried out as factory directed. Should be end of the matter..
  6. malcolm210
    malcolm210 Senior Member
    3,953
    873
    Aug 21, 2005
    Welcome! Totally agree with the above, you are between a rock and a hard place on this accepting the repair and negotiating an extension to the warranty is the best way out.
    Jim2 and Honey like this.
  7. LostKiwi
    LostKiwi Senior Member
    23,324
    12,555
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    I was under the impression MB warrant parts and repair work for 2 years? I'd push for that.
  8. OP
    Honey
    Honey Member
    14
    11
    May 21, 2020
    California
    Your Mercedes:
    Thank you
    Jim2 likes this.
  9. OP
    Honey
    Honey Member
    14
    11
    May 21, 2020
    California
    Your Mercedes:
    I will definitely look into that. Thank you
    Jim2 likes this.
  10. OP
    Honey
    Honey Member
    14
    11
    May 21, 2020
    California
    Your Mercedes:
    Thank you. Who would I negotiate the warranty with? My service advisor?
    Jim2 likes this.
  11. OP
    Honey
    Honey Member
    14
    11
    May 21, 2020
    California
    Your Mercedes:
    Jim2 likes this.
  12. OP
    Honey
    Honey Member
    14
    11
    May 21, 2020
    California
    Your Mercedes:
    Thank you. Can you suggest other places I can collect more info?
    Jim2 likes this.
  13. 00slk
    00slk Senior Member
    3,786
    2,169
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    2002 SL55 AMG, 2005 SL500 2009 SLK350
    Why did the piston crack? Bad batch, school boy error on assembly plant (dropped piston on the floor, picked it up and carried on fitting it or just real bad luck that one piston failed due to no fault?
    Just thought I would throw a spanner in the works.
    I take it that Mercedes will be crack testing the remaining pistons before reusing them?
    Honey, Jim2 and LostKiwi like this.
  14. LostKiwi
    23,324
    12,555
    Aug 25, 2006
    Your Mercedes:
    Very good point.
    Honey and Jim2 like this.
  15. Botus
    Botus Senior Member
    3,655
    835
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    ...yes, I'd be looking to hunt down other incidences of the piston cracking and how they were treated and if other's played up post repair.
    does it run as nicely as it did ? just as smooth no strange noises or vibrations?
    I guess it must be fairly common or the repair wouldn't have been just the piston.... usually they would just swap the engine over, so I guess it won't be the first one they did like this and they know its OK.
    4 years 50k miles seems odd?
    3 years and 60k miles more usual
    I would get extended Mercedes warranty... even if you have to buy a big service and pay out for the warranty, both together could be £900 but that is still a bargain to get the piece of mind for a further year.... ( you can more or less exchange £ for $ these days)
    other non merc warranties would claim the earlier repair means they aren't paying out.... and a new engine if it did come to that in the next 12k miles would be in the region of 7 to 11 k out of your pocket (so its an utter steal for the piece of mind)
    https://www.mbelcajon.com/new-vehicles/ that's a long way from here...
    Kev555 and Jim2 like this.
  16. Botus
    Botus Senior Member
    3,655
    835
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    you could always chop it in for another.... car's don't last like they used too (and put the warranty costs towards a new toy instead)
    Jim2 likes this.
  17. malcolm210
    3,953
    873
    Aug 21, 2005
    Yes, my son pays circa £700 a year for his extended warranty to cover 20k miles pa. I would imagine you will be offered a 1 year warranty on the repair and could pay to extend during your ownership. You may be able to negotiate a better deal no harm in trying, good luck with it and you may be worrying unnecessarily the repair may be fine.
  18. ajlsl600
    3,909
    1,613
    Nov 18, 2013
    france
    Your Mercedes:
    Internet, Google, search other forums collect info on any other engine issues like yrs. Keep a file. If yr able to make a decent warranty deal with Benz you may not need to bother.
  19. ajlsl600
    3,909
    1,613
    Nov 18, 2013
    france
    Your Mercedes:
    I think benz know about this failure, methinks one piston failure unusual, I have seen this when skirts, pins have cooling jets that block, come loose or even fall out. Does this motor have skirt oil jets and if so pressed or bolted in if failed piston wrecked at skirt cut away would say this the issue if not, faulty Piston, unlikely or coolant circulation in that area of block (soon know)
  20. LostKiwi
    23,324
    12,555
    Aug 25, 2006
    Your Mercedes:
    Apparently (from a quick Google) there is an issue with gudgeon pins knocking in the piston leading to piston failure on the M274 engine.
    Personally if this is true I'd demand all 4 pistons, rods and gudgeon pins be replaced as a minimum.
    The mileages for failures seem to be around 50,000 to 70,000 miles.
    Botus, Kev555, Jim2 and 1 other person like this.
Share This Page
