As previously posted (see A160 dirty engine/oil), I have a problem with my breather hose running from my tappet cover to my sump. The inside of the hose is perished and is dumping crumbs into the oil causing a sludge and a stain. I have now also been told that the hose should be reasonably rigid and in its current soft 'floppy' state would not operate as it would collapse under negative head. This breather hose failure would trap other engine/fuel contaminants in the oil, leading to an accelerated degradation of the oil quality.
What exactly does the breather hose do?
Does it operate under negative head or is there positive crankcase pressure? (It connects to the tappet cover and NOT the inlet manifold).
Thanks....
Thanks....
