slim_boy_fat
- Nov 22, 2006
As the undertray fits tightly to the crossmember and causes a water trap I asked the garage to use 5mm spacers when refitting the undertray at the rear fixings so that any water ingress could drain.
Thanks for the info izzi613, I'm sure a lot will appreciate it
Its good that you got your crossmember repaired, but I should take a close look at the transmission oil cooler pipes if I were you (they run under the radiator), they look very rusty, I just replaced mine, £36 from MBZ, not too bad a DIY job either. You really should have a look at them, you dont want to lose all your transmission fluid and bust your gearbox, that would be an expensive repair!
I take it from the posts this is very common in w210 that and the rust issues in the body panels too i think i,ll steer clear of the intended E36 AMG and stay with a W202 possibly C36 or C43.
Incidently (just out of interest) anyone know how much a new cross member from Merc would of been?
Nice job on the front cross member. I've done 3 of these myself now. Worth also looking at the front spring upper seats.
If the cross member is rotten I have found the spring seats are not far behind.
Does anyone know why the 300TD seems to be the worst affected by these corrosion probs??
