Cruise Control not working
Rinehart
Vancouver, Washington USA
1991 R129, 300SL Almandine Red, 102k
Cruise Control in my 1988 300CE has gone away. Initial symptom: When engaged the car surged forward 10/15 mph above set speed, then reverted to not working at all. After car was shut down & retested, it repeated this action. Was advisd "it is probably the Amplifier".
After installing another Amplifier, there is absolutely NO RESPONSE at all.:cry: Am now concerned that a fuse was blown upon installation. However, I can't determine even IF there exists a fuse for this device.
Can anyone give me some advice as to this quandry? It can REALLY get expensive from here. You opinions would be most welcome.
The Rock
Dan Sarf
Is the ABS warning light on? If so, could be a speed sensor. If not, please ignore me.
Rock
There are around 15 amps used in this series,all different, the system uses a hall effect sensor from the instrument cluster. If I can find any good info I will post it
Rinehart
Rinehart
cruise control
Thank you fellows. any help will be most appreciated.
Rinehart
Rinehart
cruise control
Malcolm, did you by chance, find any good info? thanks
My time ran out this week, and I will try next week when I get back
