Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
This unit was working perfectly.
I took it out to clean it.
Maybe I compressed it, and accidentally pushed the hook tab up or down.
It starts to compress under spring tension, but only travels 2 or 3 mm. Then goes solid.
It appears stuck in the up position.
I am not sure how it works. But suspect the wooden cover presses down on the lever, which allows it to compress. And then the lever locks into a new slot of that cogged wheel, near the lever.
Maybe when it was compress I accidentally pushed the lever either way that effectively skipped its normal position.
Obviously the thing to do might be compress it and then move the lever so its back where it was. But hell its now stopping compressing it!
I had hoped one could do the same thing in the up position but no way, any more pressure and the lever wills snap!
Is my logic right or is it something else?
Any ideas?
I dont drink and drive, so never use it
But bet its a fortune to replace. And the next owner may want it.
Anyone ever had this issue, and preferably solved it
I am stumped!
The unclipping action works perfectly ... but it needs to compress to shut the wooden lever.
Any ideas?
I am stumped!
