cuts out
colsmoth
wakefield,west yorkshire
hi ,i have a w220 s320 petrol 99 v reg,
since i ran out of fuel(yes ,ran out of fuel...embarrassed to say)i have been having a major problem,cutting out ,which cost me £480.00 .the garage said it was 2 injectors and mass air flow meter,.....it wasn't.it happened again the next day.the problem seems to happen at low revs,can be any distance from start,from 10 miles to half a mile.before i had the work done ,the car used to stop and take about 10-20 mins to start again,now its about 2-10 attempts at turning the engine over.Ive had it back to the garage several occasions they put it through the diagnostic machine and it comes up with no faults. please can anyone help
jibcl500
Cambridgeshire
CL500,ML55,SLK280
just a rough guess but air in the fuel lines, can you see a stream of air bubbles running through the fuel lines with the engine running or with the engine off can you see a bubble develope in the line and increase or move.
jib
Ellsy Tanners
Mars
Sounds like the crankshaft position sensor to me, very common indeed.
I am with ellsy on this one
Crank shaft position sensor £47 form a Bosch service center, or £90 from MB
C
colsmoth
cut's out
firstly thankyou for your replies,could the problem still be this crankshaft position sensor even though there are no faults being found on there machines?
Yes this is one piece that will not leave a fault code
C
colsmoth
cut's out
is there anything else it could be ,as the garage say's it can't be that sensor,
the problem is happenning alot more often now,4 times today in 12 miles.
cheers for any help
colin
And why does the garage say it cant be that
C
colsmoth
cut's out
because,they ran each and everthing through there machine and everything was fine...they said.they now say something about fuel regulator?
colin
C
colsmoth
cut's out
thankyou for your help guy's,with the troble i had with my car,
the problem was the fuel pump was bunged up.
cheers ,
colin
