Cutting out the rust...
Naraic
2005 CL500.
...on a w210 (of course).
Hole on the nearside:
This is the offside...a rotted beam under the tray below the headlamp:
Surface rust on the off side:
The worst bit cut out:
New metal being fitted for size:
That corroded beam:
Where it was fitted:
Welding in the new part...formed from steel bar:
[/UR
NW_Merc
Banned
Oop Norf
Mercedes W202
My dad's car is in a rusty state (it's also a W210). If this is the way to repair it then I might have a go starting with the front wings. From the other thread you commented on these wings you have are from ECP and galvanised arent they?
toby1
West Berkshire
I have mine for 2 more days and away it goes for its treatment!
N
Naraic
2005 CL500.
  • Moderator
It says so on the box...they are a good fit...photos when sprayed...they are fitted and the car is back in one piece now.
But here's a sample:
The insides where epoxy primed and treated liberally with Bilt Hamber Dynax wax.
Developer
S212 E63 S 5.5 biturbo
I'll give you [STRIKE]£50 [/STRIKE] £45 to take it off yer 'ands C.
NW_Merc
Banned
Oop Norf
Mercedes W202
Did you use that stuff that Clive recommended?
N
Naraic
2005 CL500.
  • Moderator
^ Yes...goes on easily and has a nice consistency...time will tell.
robfly
Event organiser
West London on sea !!
W204 C63 AMG Wagon Edition 125 2011
Forgive me for jumping in , but what is the stuff that Clive
recommend ??.
NW_Merc
Banned
Oop Norf
Mercedes W202
So as it's a wax, i'm presuming it never really dries out then
robfly
Event organiser
Thanks , I've heard Bilt Hamber do something good for applying
to corroded metal , any experience of this ??
N
Naraic
2005 CL500.
  • Moderator
  • #19
No, but they do say on the tin that it can slow down the rust process on rusty metal...time would tell.
NW_Merc
Banned
Oop Norf
Mercedes W202
You can use Jenolite. I think Bilt Hamber is a similar compound - phosphoric acid. I've normally ground back the rust as far as I can (if it's really bad then it'll need cutting away) then applied jenolite (in my case) then zinc primer, primer then topcoat.
