Mick taylor
- Mar 19, 2018
- C200k 2002. 2.0
Hi guys. I have the following codes P0263. P0266. P0269. P0272.
I cant find anything on here regarding having all four codes at the same time so apologies if I have missed it. The car is an 08 c220 cdi. Runs perfectly bur has started going into limp mode and showing those codes. I turn engine off and restart and its fine although engine light stays on but the next day its off. I recently had a small fuel leak and was told it was from the fuel temerature sensor so replaced it and it seems ok but still smells a bit. Could my problem be the high pressure fuel pump? It just seems strange to get all four codes at the same time. Thanks for any help you can give.
