stuartellis
New Registration
I purchased a 2008 cls320 back in January this year. It blew small puffs of white smoke on first start up. I was advised to renew the glow plugs which I did, this did not cure the problem. It then developed a rev related noise from the engine which steadily got worse. I was advised it sounded like a turbo problem so booked it in for an analysis at a local dealer. On the day it was booked in, the car started bellowing white smoke from the exhaust approx 5 minutes after first start up. It turned out the turbo had blown, however , the engine has also suffered considerable damage. Cylinders 1 and 5 have burnt piston heads and scored cylinders. I have been told this can happen if it burns its own oil.. However the car is back with the dealer I purchased it from and they are insisting it has been mis fuelled ie it has been run on unleaded. I put diesel in it 2 days before the incident with a receipt to prove this.
Is the damage to the engine consistent with it burning oil caused by a blown turbo. Any help or advise is appreciated.
The car has covered only 2800 in the 5 months I have driven it and it has 44000 on the clock.
