Dash board lights
Glack Attack
2004, Sprinter
Hi All. Hoping somebody can help shine some light! I have a 2000 Sprinter converted to a Camper with 126K on the clock. I have 5 lights on the dash that will not go away and have had various diagnostics plugged in to try and clear them. I will attach a picture below for further info. The two red lights to the left - one is for the parking brake which is obviously supposed to be on, the other red one is basically a warning to light to let the driver know that the other three amber lights are on with an apparent issue, however, the van drives great, never had any problems with it. No sluggish moments etc. Can anyone please suggest any remedies?
Thankyou.
Looks like a faulty wheel speed sensor
EmilysDad
Bury Lancs
ML350
Isn't the red warning light on the left with the exclamation mark in the middle a warning for low brake pads?
Trev1964
Lydney
CLS 250 cdi estate 2013
Diagnostic will answer your question.
Kev555
N.I
Low brake fluid or the sensor on the brake fluid reservoir as well could cause it?
You need a Mercedes specific code reader that can show the abs system and live data from it if need be as EmilysDad stated
G
Glack Attack
2004, Sprinter
Perfect, thanks for the suggestions! I will do some digging and be back in touch.
www.W140.co.uk&www.r129.co
