Drop the undertray and push the clock assembly out. Then at the back you will see a white ceramic square like object. This is the potentiometer. Sometimes the soldering comes apart, or the resistance wire breaks. Don't try and repair. Replace. They are about £12-14 plus vat. Remove the screws which hold it prise it off. It will be a little stiff. Then fit and reverse operation.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
