jack-s
- Jan 19, 2016
- Location
- Solihull, West Midlands
- C class -2024(73)-220d
My 73 C class has 3 USB-c ports; I want to dedicate one of them to the in built dash Cam recordings as I use the other two ports for other stuff, like for instance media playback of pre recorded Albums.
But because of the silly MB 'auto dashcam recording not allowed' for inbuilt dash cams, I use the voice command 'Hey Mercedes start Dash Cam recording' when setting off rather than fiddling with the menus each time. But! if I have media plugged into one of the other USB ports, and with the dash cam recording being set to loop/overwrite and therefore the normally used USB is always full with old recordings and over-written. When I start a new DC recording at start of a new journey the system, finding that the normal USB is full, appears to look for alternative blank space before over-writing the old DC recordings. So if I have a USB stick with music Albums inserted into one of the other ports, it starts DC recordings on whatever free space there is on that music USB stick.
That in itself is annoying but if I don't remember that the Audio USB is plugged in, when that free space is filled it then starts over-writting the music albums which is a major pain in the butt.
I've tried converting a USB from Fat32 to NTFS so that I can make it 'read only' but the MB software can't then even see it when inserted. I then removed the the 'read only' with the idea of partitioning the NTFS volume and reducing the music partition so that it's full and therefore should be ignored by the dash cam writing software. To my surprise Mercedes could read NTFS but the files appear all over the place and not contained in there respective albums. Can't partition Fat32 of course even though there are many instructions on the net saying it can be done.
The ideal solution would be to dedicate dashcam recordings to one USB port/USB stick so that it doesn't look for alternative free space but I don't seem to be able to find anyway of doing that. Does anyboby know if it's possible or have a work around. (sorry it's a bit of a ramble but dif, to explain)
