Dashboard problem
Richiecb
W204 C180 Kompressor 58 reg
Hi all, I need of some advise please.
I got into my c180 Kompressor after work and my dashboard lights up but my speedo, rev counter etc don't work.
I have looked for this problem on the forums and find conflicting comments.
I have tried to find the correct fuse diagram online but only found various different options.
Any help and advise will be appreciated
mioba
Nottingham and Köln
if you dont have a fuse chart then just test the fuses
that are in there.
easy with a multimeter across the metal tops with fuses
in place. shouldn't take 20 mins
Chrishazle
Nr Ashford, Kent
Need an indie with Star/Xentry. Something similar happened to my S204 a few months ago, Star showed that somehow the dash had lost its programming, so indie re-programmed it and all has been fine since! Didn't cost me an arm and a leg either - but then I'm very lucky with an indie I have close to me! Check around and see if you have a local taxi firm that runs a fleet of MB's and do their own maintenance so have proper Star/Xentry -and accept cash payment!!
Azazel
W204 2008 C200 CDI
I've just posted having the same problem, though mines a c200. Started up and dash is working but speedo ect doesn't. Thought after being left for a while the back Lighting on the clocks turns on and drains my battery overnight.
www.ckinsurance.co.uk
