De-misting on cold mornings - C-Class
Status
Not open for further replies.
Deejay
Surrey
I have a 2 yr old c-class. On cold mornings it mists up so badly inside that condensation runs down the windows and the rear view mirror. It takes 10-15 minutes to clear well enough to drive. Is this normal? Is anyone else experiencing the same? :(
altreed
Dorset, UK
I have experienced a few mist problems, I find that driving home with the air-con on very cold and recirculating the air in the cabin as a good way to remove damp air, so that the next morning the misting problem is much reduced.
Brrrrrrrr :wink:
G
Glenn
My C-Class is 7 year old, and I get no misting probs, just whack the air-con on with the window clearer button pressed!!
Glenn :lol:
NormanB
Portsmouth UK
Dee Jay
I do not want to cause unnecessary worry but it may be worth checking the inside of your car is completely dry.
Have a good feel round and lift carpets (at corners) if necessary and do not forget the boot too.
I get misting and I know it is caused by rear fixed windows in my venerable estate!
Good luck
NormanB
piestore
manchester
Misting C class
Is your C class 202 or 203 If its 202 ignor what I am about to say
Get in the car switch on ignition only press the two lower left buttons on the control panel together and hold ( I think demist and recirc ) till they start to flash alternatley they should flash for 10 to 15 seconds then just one light stays on switch of ignition and leave for 10 minutes. This normalises heater flaps and should solve your problem. Just check that the OSR fotwell is not wet. if it is air con drain pipe has probably come off
31806
I have a w140 S320 and had bad misting problems in wet weather. I replaced the pollen filter and this cured the problem.
regards Les.
Status
