The fuse for the stereo on the W210 is under the back seat - not that this means much on a W211. Open the fusebox under the bonnet and there should be a chart in the lid that will tell you which fuse in which fuse box you need to look at.
The fuse for the command/radio on a 211 i think from memory is situated in the boot(rear sam) this problem you have though sounds like the audio gateway is faulty so you need to get it looked at by your nearest dealer!!but removing the fuse should bring it back to life for a bit!!the fuse card in your 211 should be behind the headlight switch, to find it you have to remove the panel on the side! hope this is of some use!
Welwyn Merx Limited is a family run business with genuine passion, dedication and 25 years of experience dealing with Mercedes-Benz and AMG passenger cars. Tel: 01707 395999www.welwynmerx.uk
