dead dash lights
covlad
coventry
300E AUTO
my first thread and not sure its in the right place if not can you pls move it :)
iv no back light on the dash or heater switches ? not sure if its run by a fuse or something else as im new to mercedes as far as i can see there no blown fuses ?
Turn the trip black knob in the cluster :D
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
lol first thing i checked and the dial to the right of the steering wheel[/
If that's ok then you need to check fuses I am sure o p will guide you to the right ones, but you could start by doing a general check in fuse box. There may be bulbs behind those switches blown .
The chances ar if the dimmer is not working is that the pot has come unsoldered on one end, you will have to remove the cluster to check, there is a little red fuse that may have blown for the leds in the switches
C
covlad
coventry
300E AUTO
there is a little red fuse IS THAT THE FUSE on the cluster
C
covlad
coventry
300E AUTO
:D turned that left and right looks like the connectors needed cleaning all lights working only after i took the dash out undone the cables speedo cable off and put back in and now having problems connecting the cable lol
thankyou for the help
www.W140.co.uk&www.r129.co
