deposit left on E 320 Cdi estate.
dave9val
I have left a deposit on a E 320 Cdi estate avantgarde. When I left this deposit I didn`t know about the valeo problems. I am wondering if I entitled to insist they change the radiator should it be the valeo one, and if so, do you think they should stand the cost of replacement.. What are your thoughts on this.
No Dave you cannot insist on this on a just in case basis. By all means tell them of your concern and reasons. Are you buying from a MB dealer
D
dave9val
Yes Malcolm? I am buying the car from a main MB dealership.
Then you could work something out with them I think, and come to a good compromise
mattsurf
West Midlands
If you are buying from a main dealer I think that it would be a newer car, which is not affected by the Valeo issue. Even if it is an early car there is a very good chance that it had been rectified already
xavierx
2004 W211 E320 CDi
Mercedes used cars come with a 1 year warranty don't they? Put some glycol in your ATF and ask them to do a test and get the radiator changed under warranty lol.
You know I was only joking right .... I do not condone such dishonesty
Your mind I love it you as as bad as me LOL :D:D
Axcontrols
53 ML 270CDI, 2017 GLA200d
What's the 'valeo problem' ?
Sorry - I'm sure it's in the archive somewhere but I did a search on 'valeo problem' but there's a squillion results - people referring to the 'valeo problem' but I can't actually find anything that explains what it is.
It is where the rad leaks glycol into the gear box through a tiny hole,,this raises the surface of the clutches in the torque converter, and this maks a humming and or droning sound when pulling lightly in top gear
Axcontrols
Thank you. So is this a design fault or incorrect servicing ?
Is there a list of vehicle (types/year etc) affected ?
The cars affected were the 203,209 and 211 for cars built up to the 30-09-03, but many 04 cars have come along with this problem, and indeed a couple of 220's
www.ckinsurance.co.uk
