Diagnosing faulty injector w/s203
Clockwork
None yet
Hi all,
On the V6 320 auto is it correct that all 6 injectors need to be taken off and tested to determine faults?
It currently drives perfectly but a bit smokey on cold starts and everything else has been ruled out so want to address it asap.
Cost to send off 6 to be tested is almost the same as 6 new ones
Cheers
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
STAR and possibly some other diagnostic equipment can check injected quantities and if they are in tolerance
Pathfinder
Gourock
Is white or black smoke and what is the milage?
C
Clockwork
None yet
155k, white/blue but has had alot of work done on it recently. Oil cooler kit changed, new turbo, gaskets changed, oils all changed, terraclean equivalent.
I don't think injectors have been changed ever. I did think about having them all changed due to mileage to prolong it's life anyway
Pathfinder
Gourock
May I ask the reason for the turbo change, was the bearing shot?
C
Clockwork
None yet
Smoking was the initial reason for check but yes inspection showed the bearing was on its way out. This is all according to the mechanic but he is an mb specialist with rave reviews
Westheath
South London
Diesel Bob has a very reasonably priced test service.
Injector testing:
Conventional style injectors (not common rail) £8:00ea
Common rail injector testing £22:00ea
PD/Unit injector testing (e.g. 1.9 TDI VW) £30:00ea
A no nonsense geezer as well :)
http://www.dieselbob.co.uk/injectors.aspx
Pathfinder
Gourock
If the turbo bearing was on the way out, it is possible that the piston rings or valve seals are also on the way out, as it was the same engine oil that had been lubricating both surfaces. Could try a compression test on each cylinder.
C
Clockwork
None yet
Thanks guys
Diesel Bob sounds good shame he is so far away! I'm in Bournemouth
Thanks guys
Post them! He has a set of my kubota injectors at the moment.
Pathfinder
Gourock
Blue ish smoke issually indicates burning oil. Don't rule out the piston rings and valve seals just yet. Get a compression test done before throwing money at injectors.
