My 1996 c250 has got lots of diesel filled up in the holes where the injectors sit it also takes a bit of turning to start is it the rubber pipes that go to and from the injectors help please
On an OM606, you definitely need to buy 2 metres of leak off hose to replace it all. I don't know if you can get away with only buying 1 metre for an OM605.
The only slight note of caution is to be very careful not to scratch the pipe stubs / barbs on the injectors, or your new pipe might not seal as well as you need it to.
