Diesel mercs - how much do you top up between services
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Pinenut, Oct 18, 2012.
  1. Pinenut
    Pinenut Senior Member
    84
    Nov 11, 2010
    Manchester
    Your Mercedes:
    Mercedes C220 CDi sport 2007
    Hi, i tried a search but couldn't find similar. I have a C220 CDI 58,000 miles on a 57 plate. Service due in 3 weeks and today for the first time in 3 years the warning message asking me to check oil at next refuel came up. My driving since having the car has not changed. Same job, same area coverage, some long motorway trips and some around town.
    I drove from Manchester to Birmingham and on arrival let the oil settle then checked and level was barely at minimum. I put a litre in and later drove back and when home checked it and level near now ok near halfway. I know diesels are oil burners but i was a little suprised that never had to top up in between services in 43k miles in 2.5 years. I asked my brother who has a 59 plate C220 cdi with 98k on and he has never had to top up.
    I know it's not a big issue i have had diesels before that needed regular top up but with this i am curious what causes an engine that never asked for oil between services before to suddenly ask. I would like to ask the members of the forum for their input. Also I wonder what other C220 W204 owners have experienced with oil burn. I do understand a new diesel engine sometimes needs it when bedding in and also a high miler also may require it as the bores wear etc. but I am a little surprised that mid life 58k c220 suddenly required it.
    Ross
    P.s. Yeah I know I am being paranoid and the cars fine etc.
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    Any car will use more oil on a high speed run, this is due to the oil splash that lubricates the little ends gets picked up in the bores and burnt
  3. OP
    Pinenut
    84
    Nov 11, 2010
    Manchester
    Your Mercedes:
    Hi Malcolm , thanks for your reply.
    I agree on a long high speed run but this is a run i make every few weeks and never had the oil top up issues before.
    I was curious why something I do regularly results in this today.
    I also regularly travel Manchester to Newcastle and Manchester to Glasgow. I do these trips regularly between services and never had a top up before and I have owned the car since FEB 2010.
    Rgds
    Ross
  4. Troon
    Troon Active Senior Members
    917
    3
    Sep 16, 2011
    Staffordshire
    Your Mercedes:
    A big one
    I check mine frequently and have never had to top up. The phrase "oil burner" refers to the diesel oil, not the engine lubricating oil.
    My old petrol Mondeo would lose a litre every 2,000 miles, yet didn't leak or burn and was in seemingly perfect health. It did this from when I bought it at 70k miles to when I sold it at 149k miles.
  5. Gkinghorn
    Gkinghorn Senior Member
    2,808
    178
    Jul 25, 2009
    Bournemouth
    Your Mercedes:
    E350 CDI Cabriolet - 2011
    I had a 52 plate 220CDI .. Generally it took a litre or 2 between services.... It's not a problem... Anything much more excessive might be ... Had mine from 34k they to 110k miles ... Always the same...
  6. brianbrian
    brianbrian Senior Member
    2,747
    181
    Sep 27, 2008
    cockney in the West Country
    Your Mercedes:
    w124 250D, SL129-deisel
    Our 124/ 250d is 22yrs old high mileage and I do not have to top up between services. Hope this helps
  7. whitenemesis
    whitenemesis Senior Member
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
    My S203 CDI never needed a top up between services. 116k miles and nothing!
  8. television
    164,074
    310
    Your Mercedes:
    The thing is you never know exactly how much oil was put in at the last service, it might have been a little on the low side then, its not good to over fill a diesel. at the next service do check it your self
  9. toby1
    toby1 Senior Member
    4,901
    170
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
    Mine uses approx 1 litre every 15,000 miles.
    Yes, you are being paranoid and the car is fine
  10. Corned
    Corned Senior Member
    1,470
    5
    Jun 25, 2012
    East Midlands
    Your Mercedes:
    2005 S211 E320CDI Avantgarde
    Not reflecting at all on the OP here, but this is a classic case of technology not really helping anyone. We become reliant on stuff like this because it's there.
    I would be prepared to bet that if the car had a dipstick, it would be checked fairly regularly. Yet once we know there is a piece of technology there to do this for us, we wait until it decides that we need to do something. By which time, it is usually a little late. Just because the car is not calling for oil, does not mean that it could do with a top up. It just hasn't reached the sensor minimum level yet. Once it does, the engine is in a state whereby it reallyquite desperately needs the oil topped up to keep its protective properties intact.
    You would probably have noticed long ago if the engine needed another 1/2 litre top up - if it had a dipstick, and topped up there and then.
    Malcolm's point at post #8 is perfectly valid also. A slightly shorter fill last service will mean that, given the same driving circumstances and distances between services, you would run low on oil earlier on this occasion. The engine is likely using oil at the same rate, but from a lower baseline.
    In other words, nothing to worry about!
  11. Richie270
    Richie270 Senior Member
    88
    Sep 16, 2007
    Solihull, West Midland
    Your Mercedes:
    E270CDI 2000, 612eng
    My 270CDI with 116k might have 1/2 litre max topping up between services, and sometimes nothing at all.
  12. wireman
    wireman Senior Member
    2,632
    3
    Sep 20, 2005
    lancashire
    Your Mercedes:
    Same as Brian, my lunar distance+ 250D uses none at all, dipstick level is the same when I drain it (6000 miles) as it is when I fill it, exactly 7 litres.
  13. Rappey69
    Rappey69 Senior Member
    1,894
    382
    Dec 29, 2008
    hants
    Your Mercedes:
    c220 w204 amg sport
    w203 220, 254,000 miles and never had to top up in 4 yrs of ownership !
  14. S.Speed
    S.Speed Senior Member
    5,063
    6
    Apr 12, 2009
    Lancashire
    Your Mercedes:
    Saab 9-3
    Mine uses 6.5 litres every 7,000 miles !!;)
    But thats cos I change it then !
  15. television
    164,074
    310
    Your Mercedes:
    I still reckon that it was not filled correctly on the previous service, after all how many check it
  16. chizzel89
    chizzel89 Senior Member
    345
    Feb 27, 2011
    Pembrokeshire
    Your Mercedes:
    Mercedes-Benz C250 Turbodiesel Sport Auto. Estate. 1998. 180,000 mls
    My 176,000 mile C250 TD uses between 0.5 and 0.75 litres of lube oil every 5,000 miles which is when I change it. It doesn't leak really- never any drips on the underneath of the sump or the driveway, but the breather pipes on top of the engine ooze a bit. I do drive it hard though, and often do long high speed trips. I put it down to there being 20 valves and the stem seals maybe being a tiny bit tired.
  17. chizzel89
    345
    Feb 27, 2011
    Pembrokeshire
    Your Mercedes:
    And.... I would not worry about the oil usage you are talking about. To go from the max to the min in between services really is fine.
  18. OP
    Pinenut
    84
    Nov 11, 2010
    Manchester
    Your Mercedes:
    thanks to all for their replies. I agree it's nothing to worry about and I think Malcolm has the answer that previous service was maybe a little low oilwise. I admit I dont check the oil as much as i should. A bad admission from one who used to service his own cars back in the days of Orions,Escorts,Cavaliers, Capris etc. This has taught me to make sure regular oil checks are done. As a previous poster said we sometime let technology take over and assume car will let us know if oil level drops a little too low.
    Car does not have a worn engine or a new engine it has an engine not even middle aged (58k) so oil dips are the solution.
    Thanks for your feedback guys
    Ross
  19. television
    164,074
    310
    Your Mercedes:
    Just the way my mind works.
    If a MB fitter used ½ a liter less on every service, thats 4 liters of oil worth £40 per day or £200 per week
  20. EmilysDad
    EmilysDad Senior Member
    9,238
    2,767
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    but MB won't be paying £10 a litre, even I can buy fully skimmed MB spec oil for about £25 a gallon [​IMG][/IMG]
Share This Page
