- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
I got the digi tuner into the SL today. I used a normal house type tuner that ran on 12v, I have not done all of the aerials yet is I want to keep the other tuner intact until the last minute.
I took out the remote sensor and extended it to the front door pillar, but I will change that for a wide angle one though it works well.
I may use the draft screen as a aerial as the spacings are almost the same as a group B aerial.
Still the cost was nil and it works, I used a digi box with a RF modulator other wise every time I turned it on I would have to select Aux from the TV menu, and that is too fiddly.
