Dipped Beam Bulb
Spikeymikey
London
ML270CDI
Help,
My right dipped beam bulb has blown, I have changed the bulb and ok but then blows again straight away, any ideas. It is the correct bulb.
Spikey
DY2
Bexleyheath, Kent
W211 2003 E320 Cdi Automatic
Contacts clean and dry?
Using a good quality bulb?
Spikeymikey
London
ML270CDI
Yes bought 2 x lucas bulbs and both have blown
Naraic
2005 CL500.
Have you got a multimeter?
Miffy
Bromley, London
CLK 320 CAB Elegance C208
I think the idea was to verify the voltage as a dodgy regulator could be allowing an over voltage situation
Naraic
2005 CL500.
As above...a useful piece of kit for finding faults etc. Cheap on Ebay...get one.
The running voltage should be around 14 volt max, if over this then a reg pack issue but not that easy as a water cooled alternator
whitenemesis
CLS55 AMG '05
Why would over-voltage only blow one dipped beam lamp?
wireman
lancashire
If both lamps were bought at the same time (same batch) I would suspect the bulbs.
As to why would overvoltage blow just one lamp, I suggest that it would not, but would blow as many as it could and that they would be noticeably very bright for those several seconds
The over voltage condition would have to extend for some time to take out a new bulb or be of very high magnitude, if such a condition ever arose it would not be just one lamp that failed, damage to the entire vehicles electronics would be almost a certainty.
A defective regulator usually means the alternator brushes are worn, this tends to result in lower than normal average voltage with very short spikes of over voltage being generated as the duff/bouncing brush makes contact. The spikes would be clamped to an acceptable level (to a lamp bulb) say <17v or so by the battery, it is not very likely that this failure would kill off lamps.
Loss of the earth connection to the regulator (inside the package) will result in the alternator putting out as much power as is possible, however this condition is almost an impossibility on alternators with an integrated regulator, it is a real and present danger in much older systems with external control gear, the last time I saw this was on a seventies Jag 420G with a Lucas 11AC alternator, every lamp on the car failed. I have dealt with similar problems on Prestolite, Butec and Delco charging systems.
A defective battery connection may also be causal of such voltage excursions but this fault is normally accompanied by poor starter motor performance.
I have found Lucas lamps to be reliable and have them on my mental list of usable parts, perhaps I should consider putting them in the second division.
Uncle Benz
West Sussex
Mainly Mercedes
It is important too not to touch the glass while fitting the bulb. Finger residue on the glass can lead to premature failure.
