Dipped headlight on w212 E- 250 CDI Blue Efficiency - Year 2012 reg
lost_bird
London
S320/2003/3.2
Hello there to all gurus,
A week ago, my car had message displayed for dipped headlights not working and light wasn't working on right hand side (drive side).
Changed the bulb (HID - D1S) but light still don't work and message warning still coming up.
Are there any specific fuse which I can check?
I did read on some other forum where 2 fuses 29 and 30 (located in engine bay on driver side) for left and right head lights.
I removed the both fuses (10 amp) and was expecting that both side light should not work nut left side lights were working. My assumption is that those mentioned fuses are not the correct one.
Does anyone know the correct fuses I should check please?
Many thanks in advance.
Bobby
JBell
Torquey
C350 CDi Estate (GAD Edition)
Sounds like you should check the Ballast as well
L
lost_bird
London
S320/2003/3.2
Thank you for you reply. I will have to buy a Ballast just to check if that's the one. Unfortunately, it's too much work to to take out a bulb or replace them.
Can't even swap sides to check to rule out.
