B
bassbluestew
Ok, I KNOW there are many, many threads on this subject, and I HAVE searched them - honest, but I'm still not having any luck.
Problem is, until I recently started playing with it, my nearside mirror dipped fine, but now it won't. It does move a wee bit ( the same every time ) so I suspect it needs reset.
As I said, I have tried every possible variation of the many instructions on here ( ignition on/off, engine on/off, green button pressed with/without seat program number, in/out of rev gear ), and also in the manual ( which is a bit confusing tbh ), can someone please, please, please post definitive instructions on how to re-program the mirror. The car is a 1998 W210 E300TD.
Should the joystick type button in the centre you use to move the mirror be depressed at any time, I know the mirror selector should be and that it won't work if not.
Many thanks in advance, my ears are beginning to hurt from SWMBO,
Stewart
Stewart
