Directional brake pads
Graeme 1978
South Shields
E220 2012 2.1
Can anyone explain which side does the brake pad with the cut out which looks like a letter C on the back of the brake pad go to is it the piston side or the outer side and does it go to the top of the piston or the bottom of the piston on a mercedes w212 e class 2012 2.1 auto deisel front brake.
Sent from my SM-A520F using Tapatalk
Mark A
Aberdeen
58 ML-320CDI.
The cut out is for the wear sensor and generally goes to inside and at top. Check your old ones when you pull them out.
G
Graeme 1978
South Shields
E220 2012 2.1
Cheers
So the cut out should be on the piston side and at the top
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
As Mark A has stated, not all Mercedes are the same so check the Location when you remove the old Pads. Although the Sensor is generally is inserted into the Outside Pad, (nearest the Wheel) on the front and the Inside Pad on the Rear.
It's always a good idea to take a photo before you start to remove the Pads for future reference.
G
Graeme 1978
South Shields
E220 2012 2.1
Cheers the pads a took out didn't have the half moon cut out that's what through me
The direction pads typically have an ARROW on the back, that goes in the direction of rotation.
The half moon cut-out is for the piston, so should go on the side of the calliper with the piston
