Disconnecting the Battery on a 2006 SLK 280
Minchroadster
On-site (Cheadle Hulme)
280 SLK (2006) Obsidian Black
Guys, if I disconnect the battery (to remove it) will it be straight forward to reconnect or will I need codes or something?
Want to clean around the battery box etc. but just a bit nervous about disconnecting the battery in-case I'll need something from Mercedes to start the car?
Help please?:confused:
Mark
Nothing needed on your car Mark,, you will have to re set the widows and roof, along with the ESP. Just turn the steering from lock to lock 3 times,, and for the windows ,just close them and hold the switch in the up mode for 10 sec in Key2
M
Minchroadster
Malcolm, thank you so much.
Assume K2 means 2nd position for the key when inserted in the ignition:?:
Mark
Alex Crow
Super Suffolk
yes, and up mode on the switch means the first click, not the second.
