timmmy
does anyone know if it is possible to dismantle the basic type key to remove the key blade? i'va had to replace the ignition barrel and so now have one key for all the doors, and one for the ignition, however, i still need to put the original key up to the transponder sensor in order to start the engine. just thought it would be cheaper and easier to swap the key blades as you don't need the transponder to open the doors???? and frankly it's a pain in the arse.
cheers.
Any info will be more than gratefully recieved
cheers.
