Mercedes recommend taking off the connection at the bellhousing for the Oil cooler pipe to drain the TC
If taking off this pipe, connect a hose and point it into a bucket. start the engine and drain off 3 liters. Add 3 liters of fresh ATF and repeat this process twice.
