DIY Ceramic Coat ?
I was watching some YouTube stuff last night about Ceramic coatings and I think I may consider attempting it in the future . I do have access to a double garage at my parents in Wales so I could control the environment/weather .
It does look doable on YouTube . Has anyone who is untrained attempted any form of Ceramic coating ?
How did you get on with it ?
Binnedit
Stoke on Trent
CL500 W216
Nope, not rocket science, but I've only got a small single garage - so its a no from me :(
If it wasn't the fact that I could use a double garage I wouldn't even ask the question . Cars that have been coated do look super shiny .
Ive seen a video or two on the subject and it does look doable Wighty (seen my guy doing it too)- just needs a well prepared car, space (tick in your case) and if necessary a heat lamp to help it along the curing process.
I feel I may have posted this before but just in case...
http://gyeonquartz.com/q2-collection/
bembo449
gainsborough , lincolnshire
my mate had his Porsche done and
I didn't think much of it pal , only when he got a winter detail from another place did it look super shiney , so I guess he may have been had the first time round ?
I think the only thing to be wary of is applying too thick as apparently it can be a swine to remove.
CJD
Bourne
C200 AMG Line, Premium Plus, S205 Estate, 2018
I have seen some fantastic examples, but for it to be successful the paint has to be prepped very well before application.
If done correctly it can have outstanding results.
daveenty
The Frozen North :(
2019 AMG S Class Coupe
I too have heard this, particularly about the removal, and it put me off doing the coating myself as I'm not the most careful of people. I do like the look of it and remember when Developer John had his done some years ago, possibly one of the first I'd seen.
I looked into it, decided it was beyond my limited range of skills, and decided against attempting it myself. I never got round to getting it done on any of mine in the end, ending up with my normal cleaning regime which involves plenty of polish and wax. :)
C350Carl
Middle East
BMW 740Ld xDrive
Please please please do NOT try to apply a ceramic coating yourself. If you get it wrong the only way to remove it is wet sanding!
You may get away with it with some of the cheaper stuff. But Gyeon & GTechniq you will be in for a very hard time if you get it wrong. It is not something you should be doing on your drive or in your garage at home.
You need a sterile environment. So unless you have an uber clean garage with no chance of any dust etc then pay a professional to do it.
Thanks Carl , I know this is in your wheelhouse and I was waiting for your reply . I hear what you are saying about the application but you have only slightly dented my enthusiasm , I do research things carefully and I am able to do nearly all practical things once I've studied up . My Dads garage is very clean and can be made Draught free easily . I'm still a fair way from doing it although after your warning I may try it on a couple of other chumps cars first (family) . I do appreciate the advice and consider myself warned .
Morethanpolish
Stamford
CLK 200 Kompressor
There are products that are designed for enthusiast application like the Race Glaze 9H system which is so easy to use, and very forgiving. Thorough instructions are provided and as long as you read and follow them, you will achieve amazing results. You do have up to 20 minutes in these low temperatures to buff off and ensure the finish is perfect before you walk away.
I have spoken to several customers who have not used a Ceramic before and they are delighted having used it.
As long as the car is properly prepped and you can keep the dust away, you really do not need a hermetically sealed, clean air dehumidified environment wearing white gloves and a face mask and a white chemical/biological suit.
The product will cure sufficiently in 20 minutes to bead water so it will be hard enough for no dust to adhere.
By all means try it on a spare panel or old car but the first car I used a ceramic on was my venerable Porsche. Outside, on a dry warm and calm day.
That's very good to know thanks .
its good to get the pro's and con's from folk who have experience of this stuff
Very true ! This forum is a goldmine for other people's experiences
