DIY leak off test results - what do they mean?!
Melvin C. Yowser
I did a leak off test to my 2000 W202 C220 CDI. I did the test 3 times. On my auto C class once you've activated the starter it will turn over for a few seconds without holding the key. For each test I did this 4 times and then measured the quantity of diesel that emerged from each injector. The results were pretty much the same on all 3 occasions:
Injector 1: Just over 1ml
Injector 2: Just over 2ml
Injector 3: Under 1ml
Injector 4: Just under 2ml.
The question is: do these results actually mean anything?! Is this sufficient proof that one or more of the injectors are faulty? As I'm looking at £200 to supply and fit each replacement injector, I'd greatly appreciate any wise input anyone could give me!
Cheers!
GEORGEROV
Morayshire
Hi Melviin. As a first step I would have the injectors ultrasonically cleaned by a Bosch or Lucas service centre.
Ellsy Tanners
Mars
I think those results show injectors are fine.
A faulty injector has a constant dribble coming from it.
Autofix
Coin, malaga, Spain
www.kaneautomotive.net
SL600
Common rail leak off will only make sense if measured properly. The amount of leak off must be expressed as a capacity, cubic centimeters, mililitres etc over a given period of time. Also the injectors must be disabled during the test.
I use graduated tubes for testing so I don’t have the quantities off the top of my head but if you are stuck I can look them up for you later.
Do you have a reason to suspect the injectors?
M
Melvin C. Yowser
Cheers for the feedback!
I certianly do suspect my injectors because the car won't warm start even though it's had a new battery, new plastic fuel lines and a crank sensor fitted. During the tests, following advice from the forum, I disconnected the cam sensor - does that 'disable' the injectors? Any further info you can give would be much appreciated!
Ellsy Tanners
Mars
When a car wont start with a faulty injector, it is normally just one that has a huge difference in leak off amount compared to the others.
It looks like all 4 of yours have roughly the same amount of leak off, so to have all 4 go down at once is very unlikely IMO.
