Do I need special tool W124 front springs?
mikestrivens
Stockport
The right tools will always make the job quicker and safer and in the long run possibly cheaper.
Waft
Waft
Cambridgeshire
1993 E220 Sportline Coupe
  • #23
Thanks Mike and Graeme!
And can I DIY the rears with External Spring Compressors,or with no compressors at all and just lower arm down??
Is yours the 96/P plater Coupe then Graeme??
Did the very last ones have any goodies added to them,to clear the parts bins a bit??
TIA
Steve:D
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Removing the front coils is the same as the rears, yes rears smaller and yes just a deadly !!
jib
Waft
Waft
Cambridgeshire
  • #25
External spring compressors won't fit in then?
kth286
E320 Coupe 95
jib
Not as deadly, because the spring sits deep in the 'lower spring link' recess,
and will not be jumping out very easily.
By the time you have lowered the link a little, there will not be much tension
remaining in the spring.
grober
Scotland
W204 C200cdi estate
TIA
Steve:D
Yup that's mine. Funnily enough the last W124 220 coupes were not full of goodies They deleted the outside temperature gauge-- had the older design 15 hole alloys rather than the 8 hole alloys and one or 2 other cost cutting measures-- I don't think the 6 cylinder models had this cost cutting but they were quite a bit more expensive.
Because of restricted access using a trolley jack and lowering the suspension arm from its inner mounting bolt is the easiest way to do the rears IMHO without the right internal spring compressor tool
